[Gdal-dev] GDAL 1.2
Ben Discoe ben at vterrain.org
Fri Feb 27 02:42:03 EST 2004
Tim,
See the recent thread, "OGR, SHP, and multi-polygons" where this was
discussed..
To summarize, OGR will report that particular kind of file as type
OGRPolygon, but the geometries inside it are actually (some of them)
OGRMultiPolygon.  So you need to check the type of each geometry as you read
the file with OGR.  Making an assumption that they're all OGRPolygon would
result in exactly the picture you posted.
(This assumes, of course, that the MultiPolygon-detection code in GDAL is
working - and Frank said it is...)
-Ben
> -----Original Message-----
> From: Tim Sutton
> Sent: Friday, February 27, 2004 2:13 AM
> To: gdal-dev at remotesensing.org
> Cc: qgis-developer at lists.sourceforge.net
> Subject: [Gdal-dev] GDAL 1.2
> Hi
> (With apologies for cross posting)
> I just upgraded to gdal 1.2 from cvs. I was hoping it might
> resolve an issue I
> am encountering with ogr seeming to omit shapes from one of
> the esri sample
> datasets (countries.shp). However it doesnt :-(
