[Gdal-dev] The whole dataset in memory?
Petteri Packalen packalen at cs.joensuu.fi
Fri Jan 2 12:59:04 EST 2004
Is there any way in GDAL to load the whole dataset in memory? VRT
Dataset can be created "in memory", but is it possible to load actual
pixel data to memory as well. I would need as fast access to band data as
possible (memory consumption is not a problem).
Petteri
