[Gdal-dev] a question about reading a .bmp image
Andrey Kiselev dron at ak4719.spb.edu
Tue Jan 6 05:50:08 EST 2004
On Mon, Jan 05, 2004 at 08:03:59PM +0100, EloisaNerea at ono.com wrote:
> Hi ?Could you explain me how I can read the information bit by bit of
> a .bmp image ?
GDAL data model doesn't support packed bytes. Bilevel BMP files will be
internally converted to the 8 bit representation and two colors will be
coded with 0 and 1 values (or values from the color palette, if file
contains the one). So you can read bilevel BMP file in the same way as
8bit one.
					Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
