[Gdal-dev] Conversion formula
Daniel McAferty dmcaferty at seeop.net
Wed Jan 7 09:42:03 EST 2004
I had the same question a few weeks ago. It is a lot tougher than I thought
but I got things to work.
Here are some web sites that helped me get the info I was looking for.
http://www.gpsy.com/gpsinfo/geotoutm/
    This is good starting place as it has many links to places that has info
http://www.posc.org/Epicentre.2_2/DataModel/ExamplesofUsage/eu_cs34.html
    This is a paper that explains some of the different datums and the math
formulas
    to convert from Lat/long to UTM and back. It also has a link to an
example to convert from
    lat/long to UTM. It only goes the one direction. But I found the souce
code of that html example
    helpful in my own programs.
I also found some helpful code examples on
http://www2.ifjf.uib.no/latlong2UTM/
good luck,
Dan
  -----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Support_Fluidyn
  Sent: Tuesday, January 06, 2004 2:12 AM
  To: gdal-dev at remotesensing.org
  Subject: [Gdal-dev] Conversion formula
  Dear Sir,
  I  would like to know the formula required to convert UTM coordinates into
standard lat/long coordinates and vice versa.
  I am looking forward for your reply and  would be thankful for the same.
   Thanking you,
  Nisha
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040107/bda0536f/attachment.html
