[Gdal-dev] about kakadu compile
Mon Jan 12 14:26:05 EST 2004
Fu Chen wrote:
> Hi!
> Does anyone compile the gdal with the kakadu sdk 4.1 recently?
> In nmake.opt there is only one dir to supply. But in fact the kakadu's
> include files spread in many directories. At last I collect all the .h
> file into one directory. But the compile still have trouble.
> jp2kakdataset.cpp(599) : error C2039: "set_num_components" is not a
> method of kdu_window
> jp2kakdataset.cpp(600) : error C2676: "[" : "kdu_range_set" doesn't have
> this operation.
> How can I get rid of this error?
> Any idea?
Fu Chen,
I suspect that something has changed in the JPIP related code, but I haven't
built that portion (available only on win32) against Kakadu 4.1.  You can get
things working by dropping JPIP support.
Change this:
#if defined(KAKADU4) && defined(WIN32)
#  define USE_JPIP
#endif
To this:
#if defined(KAKADU4) && defined(WIN32) && !defined(KAKADU41)
#  define USE_JPIP
#endif
I will apply this change to the master source till I get around to fixing
up JPIP support on 4.1.
Best regards,
