[Gdal-dev] MrSid
Bjoern Ruff br at forstware.de
Tue Jan 13 12:15:33 EST 2004
Hello Frank,
thanks, it works!
Bjoern
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Frank Warmerdam
> Sent: Tuesday, January 13, 2004 5:33 PM
> To: gdal-dev at remotesensing.org
> Subject: Re: [Gdal-dev] MrSid
> Bjoern Ruff wrote:
> > Hello,
> > I just compiled gdal with VC71 and MrSid DSDK 3.2.1
> > I sent the neccessary changes to Frank.
> > Now I wanted to test it with test_ogrsf
> > I got the message: Unable to open datasource ... with the following
> > drivers. .....
> > What must I do to get test_ogrsf to use the driver. test_ogrsf was
> > linked with the MrSid lib's.
> Bjoern,
> The test_ogrsf program is only used to test OGR vector
> drivers, not GDAL
> raster drivers.   Best to test by doing a gdalinfo on the
> .sid file, and
> then a gdal_translate to convert to another format and check
> if it looks OK.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal> -dev
