[Gdal-dev] SDTS Multiband Raster Reading Problems
Wed Jan 14 10:11:38 EST 2004
Tim Sutton wrote:
> Hi
> I am trying to implement SDTS format support using gdal. Gdal manages fine for
> single band datasets such as dem's, but when I try to open multiand imagery
> data such as:
> http://thor-f5.er.usgs.gov/sdts/datasets/raster/erdas/GainesvilleGA-bedr.sdtsrp.tar.gz
> Gdal errors with:
> ERROR 1: IReadBlock failed at X offset 0, Y offset 184
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 184
> ERROR 1: Cell record is not of expected format.  Raster access failed.
> Running gdalinfo on the file shows that gdal thinks it is a single band
> (instead of 7band) image.
> Is mulitband sdts imagery supported or planned by gdal?
Tim,
I have never encountered a multi-band SDTS product before!  Do you have a
real need for multi-band SDTS support, or are you just trying all the assorted
data products you could find?  If you need it, I could look into implementing
it.  Please submit an enhancement request in Bugzilla.
Best regards,
