[Gdal-dev] Help with seg fault
Tyler Mitchell TMitchell at lignum.com
Thu Jan 15 19:48:23 EST 2004
I'm running GDAL from CVS on Cygwin and am getting a core dump when using
ogrinfo.
Does this info mean anything to you:
$ ogrinfo ifpa
Had to open data source read-only.
INFO: Open of `ifpa'
using driver `AVCBin' successful.
Exception: STATUS_ACCESS_VIOLATION at eip=00401508
eax=00000004 ebx=102A0AD8 ecx=00000000 edx=00000000 esi=00000000
edi=00000000
ebp=0022FEF0 esp=0022FE50 program=C:\cygwin\usr\local\bin\ogrinfo.exe
cs=001B ds=0023 es=0023 fs=0038 gs=0000 ss=0023
Stack trace:
Frame     Function  Args
0022FEF0  00401508  (00000002, 61600B34, 102A0330, 0022FF24)
0022FF40  61005018  (610CFEE0, FFFFFFFE, 000003D4, 610CFE04)
0022FF90  610052ED  (00000000, 00000000, FFFFFFFF, 8043138F)
0022FFB0  00405E02  (00401330, 037F0009, 0022FFF0, 7C5987E7)
0022FFC0  0040103C  (00000000, 00000000, 7FFDF000, 00000000)
0022FFF0  7C5987E7  (00401000, 00000000, 000000C8, 00000100)
End of stack traceSegmentation fault (core dumped)
