[Gdal-dev] ERROR import Shape to PostgreSQL
Düster Horst Horst.Duester at bd.so.ch
Fri Jan 16 02:19:31 EST 2004
Hallo
Today I made an upgrade of gdal/ogr from 1.1.7.2 to cvs-040114. GDAL-1.1.7.2
works very stable but I need to convert POLYGON to MULTIPOLYGON. Hence I
made the upgrade. But now I'm not able to convert ESRI Shape to PostgreSQL
in all cases. So some shapes which could be imported by the former Version
of GDAL without problems  breakes down the import process with the following
error message:
ERROR 1: INSERT command for new feature failed.
ERROR:  couldnt parse objects in GEOMETRY
ERROR 1: Terminating translation prematurely after failed
translation of layer lieg_lieg_geom
I start ogr2ogr with the following command string:
ogr2ogr -f postgresql PG:dbname=hdus lieg_lieg_geom.shp -lco overwrite=yes
-lco launder=yes -lco precision=no -nlt MULTIPOLYGON -nln liegen
To reproduce this error I can send the mentioned shape.
It would be great to solve this probem.
Best regards
Dr. Horst Düster
GIS-Koordinator
Amt für Geoinformation
Abteilung SO!GIS Koordination
Werkhofstr. 65
4509 Solothurn
Tel.: 032 627 25 32
Fax: 032 627 22 14
horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
www.sogis.so.ch <http://www.sogis.so.ch/>
