[Gdal-dev] nad27 problem?
Tom Parker tapadmin at swbell.net
Mon Jan 19 20:25:16 EST 2004
Hello,
I'm porting an application from windows to linux and have run into a
puzzling problem while attempting to project a USGS dem file to UTM zone 14.
I'm using the current gdal and proj from cvs on a fully patched redhat 9
system and have run configure, make and make install on both projects with
default arguments.
The problem is the projection routine is failing and giving me the error
message.
ERROR 1: failed to load NAD27-83 correction file
ERROR 1: Reprojection failed, err = -38, further errors will be suppressed
on the transform object.
I've tried a few ideas from searches of the mailing list:
- uncompressing the original files from the archive to make sure no windows
<=> linux silliness is happening.
- using gdalinfo to make sure the dem file is readable, everything looks
normal.
- setting PROJ_LIB=/usr/local/share/proj/
- adding printf statements to LoadProjLibrary in ogrct.cpp to make sure the
library was really loading, it is with no issues I can see.
I'm a bit stumped :(
Any ideas would be greatly appreciated.
Regards,
Tom
