[Gdal-dev] SRTM file format
Gillian Walter gillian.walter at atlantis-scientific.com
Wed Jan 21 13:00:39 EST 2004
For those of you who also use openev, Andrey has added a neat tool for
reading raw binary files (it adds a menu entry File/Open Raw... that
launches a gui allowing you to specify lines, samples, number of bands,
interleaving, datatype, header size, byte swapping).  This should
eliminate the need to manually create header files for viewing flat
binary files in openev.  This tool is new though, so you'd have to get
it from cvs.
Gillian
Frank Warmerdam wrote:
> mathieu_gdal wrote:
>> Dear all,
>> Is GDAL compatible with the STRM file format?
>> This format is used to encode DEMs, and it is in binary. The
>> extension is
>> hgt.
>> I have made a try, it looks like it is not recognize by GDAL, but maybe
>> there is a trick?
>> In advance, thank you
>> Mathieu
> Mathieu,
> My understanding is that the .hgt file is a raw binary file.  It can
> be read
> with GDAL using an appropriately written ESRI BIL .hdr file or some other
> mechanism that desribes raw data files (such as PCI .aux).  I was under
> the impression the data was distributed with an ESRI BIL .hdr file but
> that
> some sort of renaming was required to get things working properly.
> There was some sort of past discussion of this on the gdal-dev, grass or
> VTP list.  Not sure which.
> Best regards,
