[Gdal-dev] Re: Fix for PNG byte order problems under x86
Robert Osfield robert at openscenegraph.com
Thu Jan 29 09:22:55 EST 2004
Oopps, last minute change to the code which I submited didn't compile... the
#if should have been an #ifdef :
#ifdef CPL_LSB
    // png are stored as MSB/big endian, so we'll need to swap bytes if on a
    // LSB/little endian machine.
    if (poDS->nBitDepth>8)
        png_set_swap(poDS->hPNG);
#endif
File attached.
Robert.
Type: text/x-c++src
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040129/91c610d3/pngdataset.bin
