[Gdal-dev] Re: Fix for PNG byte order problems under x86
Robert Osfield robert at openscenegraph.com
Thu Jan 29 10:15:25 EST 2004
On Thursday 29 January 2004 14:55, Frank Warmerdam wrote:
> Robert,
> Would you be able to provide a redistributable same of a 16bit png file?
> I have applied your pngdataset.cpp changes in CVS.
I download them from the Puget Sound Terrain project website:
	http://www.cc.gatech.edu/projects/large_models/ps.html
I was using this as a test example, the elevation map is a 16bit PNG file.
Cheers,
Robert.
