[Gdal-dev] Re: Fix for PNG byte order problems under x86
Thu Jan 29 15:44:58 EST 2004
Robert Osfield wrote:
> On Thursday 29 January 2004 18:59, Frank Warmerdam wrote:
>>Robert,
>>It seems the png_set_swap() function wasn't working for me.  I have
>>modified the code to explicitly swap the data in the row reading method.
> Could it be that the code doesn't pngdataset doesn't directly include
> cpl_port.h so CPL_LSB is never defined, so the png_set_swap never gets
> called?
Robert,
I don't think that's it because I have my code in an #ifdef CPL_LSB
as well.  In fact, the png_set_swap() did *seem* to change the data, but it
just wasn't correct. I don't know what I'm missing but for now I'm not worried
about it.  I just wanted to let you know.
> I must admit I hadn't tested the addition of the #ifdef against the datafiles
> today.  Originally when I did the testing it was without any guards, it
> worked fine back then.  Sorry about this, I'm afraid my thoroughness has
> obviously slipped, like yourself toooo bussyyyy!!!
No problem.  The issue might be a quirk in my copy of libpng ... who knows.
Best regards,
