[Gdal-dev] Problem writing to MapInfo files
Daniel Morissette dmorissette at dmsolutions.ca
Wed Jul 7 15:26:25 EDT 2004
Woon Wei Lee wrote:
> Hi all
> I have been trying to put together a little program to re-write data from an existing *.TAB file to a new layer but with different colours for the features (I am working on an app to process traffic data then return a colour-coded congestion map) but the ogr library refuses to transfer the stylestring info over to the new layer.
> I noticed from a previous posting that this is a known bug ( http://xserve.flids.com/pipermail/gdal-dev/2004-July/006558.html ) so I thought I could have a short at debugging it but I can't seem to find the relevant part of the ogr source.
> My program uses the function OGR_L_CreateFeature() from the c api which is a wrapper for OGRLayer::CreateFeature() but the closest I can find is this bit of code from ogrlayer.cpp:
> OGRErr OGRLayer::CreateFeature( OGRFeature * )
>     return OGRERR_UNSUPPORTED_OPERATION;
> which presumably is a stub for some driver specific version which is contained in another file.. however I just can't find where the "real" function is. Could anyone help me out please??
The TAB driver's CreateFeature() is implemented in
gdal/ogr/ogrsf_frmts/mitab/mitab_imapinfofile.cpp
  DM Solutions Group              http://www.dmsolutions.ca/
