[Gdal-dev] gdal config icluding xerces
Daniel Isenegger disen at geo.unizh.ch
Fri Jul 9 08:43:15 EDT 2004
Hi
i have installed grass57 on suse9.1 and want to use gdal for the
grass-commands v.in.ogr and v.out.ogr. When applying v.out.ogr xerces is
needed by gdal.
when compiling gdal to use xerces i get the following errors (2
different tries in the following):
- when using xerces 2.1.0 (built from source):
./configure --with-grass=/usr/local/grass-5.7.0
--with-pg=/usr/local/pgsql/bin/pg_config --with-xerces
--with-xerces-inc=/downloads/xerces/xerces-c-src2_1_0/include
--with-xerces-lib="-L/downloads/xerces/xerces-c-src2_1_0/lib -lpthread"
--with-odbc=/usr/local/lib --with-static-proj4=/usr/lib/libproj.so | tee
configure_disen.log
checking for Xerces C++... requested, but compile or link fails!
g++ -I/downloads/xerces/xerces-c-src2_1_0/include -o conftest
conftest.cpp -L/downloads/xerces/xerces-c-src2_1_0/lib -lpthread
-L/usr/local/grass-5.7.0 -L/usr/local/grass-5.7.0/lib -lgrass5 -lz -lm -ldl
conftest.cpp:1:34: util/PlatformUtils.hpp: No such file or directory
conftest.cpp: In function `int main()':
conftest.cpp:5: error: `XMLPlatformUtils' undeclared (first use this
function)
conftest.cpp:5: error: (Each undeclared identifier is reported only once
for
   each function it appears in.)
conftest.cpp:5: error: syntax error before `::' token
configure: error: Please correct Xerces options, or don't enable Xerces.
- when using Xerces 1.6.0 (binary):
--with-xerces-inc=/downloads/xerces/xerc./configure
--with-xerces-inc=/downloads/xerces/xerces-c1_6_0-linux/include
--with-xerces-lib="-L/downloads/xerces/xerces-c1_6_0-linux/lib
-lxerces-c1_6_0 -lpthread" --with-odbc=/usr/local/lib
--with-static-proj4=/usr/lib/libproj.so | tee configure_disen.log
g++ -I/downloads/xerces/xerces-c1_6_0-linux/include -o conftest
conftest.cpp -L/downloads/xerces/xerces-c1_6_0-linux/lib -lxerces-c1_6_0
-lpthread -L/usr/local/grass-5.7.0 -L/usr/local/grass-5.7.0/lib -lgrass5
-lz -lm -ldl
/usr/lib/gcc-lib/i586-suse-linux/3.3.3/../../../../i586-suse-linux/bin/ld:
cannot find -lgrass5
collect2: ld returned 1 exit status
- with xerces 2.1.0: the file util/PlatformUtils.hpp is there
(The environment variables XERCESROOT, PATH, LD_LIBRARY_PATH are set to
the appropriate directories)
- with xerces 1.6: what is the difference in the error message? coming
from the same problems?
- how to solve them?
I browsed trough the archives and found similar errors, but no
suggestions to fix them (:-(
Any ideas?
Thanks Dani
