[Gdal-dev] GDAL install patch
Bernhard Reiter bernhard at intevation.de
Mon Jul 12 09:39:00 EDT 2004
There is a small change to GDAL's install-sh
and a fedora2 rpm.spec behind the link below.
Will that be taken up by GDAL development?
	Bernhard
On Thu, Jul 08, 2004 at 05:03:45PM +0200, Silke Reimer wrote:
> I created a grass 5.7 package for fedora version 2 and a few library
> packages (gdal, proj and shapelib) which are normally necessary when
> you want use free GIS software ;-)
> You can download the Spec-files with the patches as well as srpms
> and rpms from
> 	http://ftp.intevation.de/users/silke/packages/fedora/
> They are located in SPECS, SOURCES, RPMS and SRPMS respectivly.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040712/59654ae2/attachment.bin
