[Gdal-dev] Compiling ogr/gdal on win32 using MingW
Norman Vine nhv at cape.com
Wed Jul 14 11:18:38 EDT 2004
Woon Wei Lee writes:
> Sorry, feeling really ignorant here but I don't quite get what u mean by running
> ./configure on windows... afaik configure is a bourne shell script so it won't work on
> windows (unless I use cygwin, but I'm really trying to avoid that - would rather use
> mingw if possible) ... I hope I'm missing something really obvious here...  :-(
http://mingw.org/msys.shtml
or do as I do and install a MingW tree inside of Cygwin
i.e.  I have established my MingW root at /usr/mingw
and install mingw files under it
then  # mingw make doesn't understand Unix filenames
% cp /bin/make.exe to /usr/mingw/bin
and when I configure a MingW build I use
./configure --prefix=/usr/mingw --host=mingw32
note
$ gdal-config --libs
-L/usr/mingw/lib -lgdal
$ gdal-config --prefix
/usr/mingw
$ gdalinfo --version
GDAL 1.2.1.0, released 2004/06/23
HTH
Norman
