[Gdal-dev] Kakadu float rasters and 16bits lossless
Julien Demaria dem at acri-st.fr
Fri Jul 16 11:49:12 EDT 2004
Frank,
sorry I've just seen in the source this comment (and thought the
documentation was outdated...) :
  * Revision 1.20  2004/01/15 21:21:04  warmerda
  * added lossless compression of 16bit values
but haven't verified that... (a little test with diff seams fails...)
Other question :
I searched on gdal web sites for a CVSWeb ; is it disabled ? (I've found
only http://www.remotesensing.org/cgi-bin/cvsweb.cgi/osrs/gdal/ on
http://gdal.maptools.org/download.html but it doesn't works...)
Regards,
Julien
At 11:12 16/07/2004 -0400, Frank Warmerdam wrote:
>Julien Demaria wrote:
>>Hi,
>>The Kakadu driver can create float rasters and compress 16bits rasters
>>lossless, so this line in the driver sources should be updated :
>>         poDriver->SetMetadataItem( GDAL_DMD_CREATIONDATATYPES,
>>                                    "Byte Int16 UInt16" );
>>and also the driver documentation
>>(http://gdal.maptools.org/frmt_jp2kak.html) :
>>"... When reading images this driver will represent the bands as being
>>Byte (8bit unsigned), 16 bit signed or 16 bit unsigned.
>>NOTE: QUALITY=100 will not be lossless for 16bit images."
>Julien,
>Have you verified broadly that 16bit signed and unsigned images can be
>compressed losslessly?  I can't remember why I put this comment in the
>document, but I am hesitant to remove it without being able to remember.
>Also, the floating point support depends on the data being prescaled between
>0.0 and 1.0 which is then internally implicitly treated as integers as I
>understand it.  So I don't think there is really proper support for floating
>point data, though I didn't realize when I first implemented the code.
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
