[Gdal-dev] Improving img support
Fri Jul 16 16:44:14 EDT 2004
Andreas Wimmer wrote:
> Hi!
> I am currently working on using gdal specifically the img driver to access
> erdas img-images from our image processing framework.
> While working on it I found a number of issues with the gdal support for
> img images. I solved these issues with the patches I append to this posting.
Andreas,
I have committed all your patches after a rudimentary inspection, and a
verification that my imagine test suite still passes.  They are most
impressive!
Would you mind preparing one more patch?  A patch to frmt_hfa.html
explaining the current state of things?
PS. I take it this means I don't need to investigate the bug report that
came to me indirectly via Geosystems?
Best regards,
