[Gdal-dev] OGC Spec getExteriorRing() for a Polygon
Tue Jul 20 18:08:02 EDT 2004
Chapman, Martin wrote:
> Frank,
> The OGC Spec says that the Polygon method getExteriorRing() should
> return a LineString.  Just out of curiosity, why do you return a
> LinearRing from your implementation OGRPolygon::getExteriorRing()?  It
> would make sense to me that the spec is wrong and what you want is
> always a ring.  Do you think the OGC spec is wrong.  The following is
> from the spec:
Martin,
Since a linearring is a subclass of linestring, a linearring is technically
a linestring.  I don't know why the Simple Features for SQL specifies
line string.  It seems kind of brain dead, and not something I'm going to
change OGR to adhere to.
Best regards,
