[Gdal-dev] Error messages with Configure
Gillian Walter gillian.walter at atlantis-scientific.com
Tue Jul 27 12:53:47 EDT 2004
I've never seen this problem on solaris.  I generally build from a tcsh
shell, and make sure that /opt/sfw/bin is in PATH and /opt/sfw/lib is in
LD_LIBRARY_PATH.  Are you sure that the script that sets path is
actually being called in the terminal you're configuring from (entering
"echo $PATH" and "echo $LD_LIBRARY_PATH" should show these values)?
Gillian
Steve Friedman wrote:
> This is a follow-up regarding the errors I'm rec'ing as I try to
> configure gdal.
> # ./configure
> checking build system type... sparc-sun-solaris2.8
> checking host system type... sparc-sun-solaris2.8
> checking target system type... sparc-sun-solaris2.8
> checking for gcc... no
> checking for cc... no
> checking for cl... no
> configure: error: no acceptable C compiler found in $PATH
> See `config.log' for more details.
> Inspecting the config.log file shows:
> PATH: /usr/sbin
> PATH: /usr/bin
> However:
> > which c++ returns
> /opt/sfw/bin/c++
> and
> > which g++ returns
> /opt/sfw/bin/g++
> Furthermore, in setenv PATH is defined to include /opt/sfw/bin, which
> is where these programs are located.
> Why is configure only searching in /usr/bin and /usr/sbin?
> Steve
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
