[Gdal-dev] problem of gdal_translate 1.1.9 and 1.2.1 with multiplebands
Xiaodong Zhang zhang at aero.und.edu
Wed Jul 28 11:05:38 EDT 2004
Hi Frank,
I'm absolutely positive that 1.1.8 can use -b 1,2,3,4. This is how we have
been using it for the past 1.5 years.
Xiaodong
Xiaodong Zhang, Ph.D.
Assistant Professor
Earth System Science and Policy Program
University of North Dakota
Grand Fors, ND 58202-9007
(701)777-6087
Quoting Frank Warmerdam <warmerdam at pobox.com>:
> Xiaodong Zhang wrote:
> > Thanks Frank,
> > Yes you are right, I have to use gdal_translate -b 1 -b 2 -b 3 ... to
> spectrally
> > subset an image, but it only works for version 1.2.1 but not for 1.1.9.
> Version
> > 1.1.9 produces only one band regardless. Both ways of sending '-b'
> arguments,
> > i.e., -b 1,2,3,4 or -b 1 -b 2 -b 3 -b 3, work for earlier version, 1.1.8.
> Hi,
> Are you sure the -b stuff is working in 1.1.8?  It might just be ignoring it
> and
> copying all bands.
> > On aother note, are there any significant changes for versions later than
> 1.1.8.
> > In another email, I reported that our program using gdal api crashes for
> both
> > version 1.1.9 and 1.2.1, while it works perfectly for version 1.1.8.
> Well, there have been lots of changes - significant and otherwise since
> 1.1.8.
> I think you will need to debug your problem or provide something simple I
> can
> use to reproduce your problem if you would like help with it.  I can't
> imagine
> there is any fundamental reason you can't use 1.2.1.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
