[Gdal-dev] processing SRTM-3?
Wed Jul 28 16:12:35 EDT 2004
Thom DeCarlo wrote:
> ACK! I should have checked this first. (I was working from old, outdated,
> memories.) running gdalinfo on the geotiff files shows that there *is* a
> NODATA value of -32768 in there. I'd better check the other applications to
> make sure that they are handling this properly and not just assuming that
> the NODATA value is -9999.
Thom,
Sometime relatively recently a hack was put into the GDAL GTiff driver to
save a nodata valuei in a GDAL-custom tag in the TIFF file.  It isn't likely
that any non-GDAL application will recognise the nodata value in the TIFF
file.
Best regards,
