[Gdal-dev] Re: Problems when warping
Juan Cicuendez jicicuendez at gmv.es
Tue Jul 27 04:36:01 EDT 2004
Frank Warmerdam <warmerdam <at> pobox.com> writes:
> Juan Cicuendez wrote:
> > Hi everybody,
> > I am trying to change the projection of an RGB scanned map. This is my
first
> > experience with GDAL and I followed the instructions of the Warping
tutorial.
> > In order to process all the three bands I set psWarpOptions->nBandCount = 0;
> > I finally obtained the geotiff file but when I try to visualised it from
ERDAS
> > it only recognises the first band, however if I try from ENVI it goes fine
an
> > sees all the bands. Looking at the image with windows Imaging application,
it
> > looks very strange and this could be a problem with the interleaving of the
> > data. Has anybody come across this problem before? Does anybody know how to
fix
> > this problems in order that the files can be visualised from ERDAS?
> > I would appreciate if anyone could give me hand, I tried many things but
> > nothing seemed to work.
> Juan,
> By default GDAL creates TIFF files with PLANARCONFIG_SEPERATE (band
interleaved)
> but I have observed some versions of Erdas tools and other applications having
> problems with this.  You can pass the INTERLEAVE=PIXEL creation option to the
> GTiff driver when creating a new TIFF file to create a pixel interleaved file.
> Of course, if you could provide a smallish sample file demonstrating the
> problem it would be easier to determine if this is the issue.
> Best regards,
Thanks for your help Frank,
Testing your suggestion. I tried something like:
char *pszOptions = "INTERLEAVE=PIXEL"
hDstDS = GDALCreate( hDriver, outputfilename, nPixels, nLines, bands, eDT,
&pszOptions );
, but of course it didn't work. How can I pass the opticon INTERLEAVE=PIXEL
when creating the geoTiff file? I haven't found the documentation of the
GeoTiff driver. Where can I find it?
I put up all the code of the function:
CPLErr change_projection(char *filename, char *outputfilename, char *pszDstWKT)
    GDALDriverH hDriver;
    GDALDataType eDT;
    GDALDatasetH hDstDS;
    GDALDatasetH hSrcDS;
    // Open the source file.
    hSrcDS = GDALOpen( filename, GA_ReadOnly );
    CPLAssert( hSrcDS != NULL );
    // Create output with same datatype as first input band.
    eDT = GDALGetRasterDataType(GDALGetRasterBand(hSrcDS,1));
    // Get output driver (GeoTIFF format)
    hDriver = GDALGetDriverByName( "GTiff" );
    CPLAssert( hDriver != NULL );
    // Get Source coordinate system.
    char *pszSrcWKT = NULL;
    pszSrcWKT = (char *) GDALGetProjectionRef( hSrcDS );
    CPLAssert( pszSrcWKT != NULL && strlen(pszSrcWKT) > 0 );
    // Create a transformer that maps from source pixel/line coordinates
    // to destination georeferenced coordinates (not destination
    // pixel line).  We do that by omitting the destination dataset
    // handle (setting it to NULL).
    void *hTransformArg;
    hTransformArg =
        GDALCreateGenImgProjTransformer( hSrcDS, pszSrcWKT, NULL, pszDstWKT,
FALSE, 0.0, 1 );
    CPLAssert( hTransformArg != NULL );
    // Get approximate output georeferenced bounds and resolution for file.
    double adfDstGeoTransform[6];
    int nPixels=0, nLines=0;
    CPLErr eErr;
    eErr = GDALSuggestedWarpOutput( hSrcDS, GDALGenImgProjTransform,
hTransformArg,
                                                adfDstGeoTransform, &nPixels,
&nLines );
    CPLAssert( eErr == CE_None );
    // Create the output file.
    int bands = GDALGetRasterCount(hSrcDS);
&pszOptions );
    CPLAssert( hDstDS != NULL );
    // Write out the projection definition.
    GDALSetProjection( hDstDS, pszDstWKT );
    GDALSetGeoTransform( hDstDS, adfDstGeoTransform );
    // Copy the color table, if required.
    GDALColorTableH hCT;
    hCT = GDALGetRasterColorTable( GDALGetRasterBand(hSrcDS,1) );
    if( hCT != NULL )
        GDALSetRasterColorTable( GDALGetRasterBand(hDstDS,1), hCT );
    GDALClose( hDstDS );
    hDstDS = (GDALDataset *) GDALOpen( outputfilename, GA_Update );
    // Setup warp options.
    GDALWarpOptions *psWarpOptions = GDALCreateWarpOptions();
    psWarpOptions->hSrcDS = hSrcDS;
    psWarpOptions->hDstDS = hDstDS;
    psWarpOptions->pfnProgress = GDALTermProgress;
    // Establish reprojection transformer.
    psWarpOptions->pTransformerArg =
                                         pszSrcWKT,
                                         hDstDS,
                                         pszDstWKT,
                                         FALSE, 0.0, 1 );
    psWarpOptions->pfnTransformer = GDALGenImgProjTransform;
    // Initialize and execute the warp operation.
    GDALWarpOperation oOperation;
    oOperation.Initialize( psWarpOptions );
    oOperation.ChunkAndWarpImage( 0, 0,
                                  GDALGetRasterXSize( hDstDS ),
                                  GDALGetRasterYSize( hDstDS ) );
    GDALDestroyGenImgProjTransformer( psWarpOptions->pTransformerArg );
    GDALDestroyWarpOptions( psWarpOptions );
    GDALClose( hSrcDS );
    return eErr;
Cheers,
Juan
