[Gdal-dev] Vector to raster?
Thu Jul 29 13:15:49 EDT 2004
Jonathan Greenberg wrote:
> Hi there, we are interested in developing an application that creates a list of
> raster-based x,y locations from input vector data (point, line or polygon)
> (e.g. we want to rasterize the vector data for use in extracting pixel-level
> data from satellite imagery).  Can OGR or GDAL perform this task?  If so, are
> point and line rasterization calculated in an optimal way (e.g. can I go
> directly from a point or line coverage to a set of x,y coordinates without
> needing to create a large raster coverage of the extent of the line or point
> coverage first?)  Thanks!
Jonathan,
Did I (or anyone) answer this?  The short answer is that there is not any
vector to raster conversion capability in GDAL/OGR at this time.  There has
been a bit of work done in this direction in OpenEV but nothing particularly
great nor "optimal" by your definition.
Sorry,
