[Gdal-dev] Corrupted WKT in my GeoTIFF dem
Michael Logan mlogan at mail.arc.nasa.gov
Fri Jul 30 16:30:13 EDT 2004
Hello,
I am trying to create a Geotiff DEM from scratch during conversion
 from GridFloat format (i've tried multple formats (int16,float32,byte)),
 but while everything seems good, the WKT is always clobbered.
I set the WKT in my C++ code, but after closing the file and exiting,
 a gdalinfo gives "badness" for the projection portion:
% gdalinfo area79.tiff
Driver: GTiff/GeoTIFF
Size is 21600, 7200
Coordinate System is `'
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0, 7200.0)
Upper Right (21600.0,    0.0)
Lower Right (21600.0, 7200.0)
Center      (10800.0, 3600.0)
Band 1 Block=21600x1 Type=Int16, ColorInterp=Gray
So, my corners don't appear as Geographics corners
 as I'd hoped, since it appears no info is available
 to do the transform..
Here is my code for setting the projection:
    oSRS.SetGeogCS( "WGS84","WGS_1984", "WGS 84",
            6378137.0,   298.2572235629972,
            "Greenwich",  0.0,  "degree",
            0.0174532925199433 );
    char *pszSRS_WKT = NULL;
    oSRS.exportToWkt( &pszSRS_WKT );
    cout << "WKT = " << endl << pszSRS_WKT << endl;
    if( geoDataset->SetProjection( pszSRS_WKT ) == CE_Failure )
      cerr << "Failed to write projection to dataset" << endl;
and the "COUT" does do something correctly:
WKT =
GEOGCS["WGS84",DATUM["WGS_1984",SPHEROID["WGS84",6378137,298.2572235629972]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]
AND, right before I exit, I do a
    cout << "Final request for projection string = " << endl
     << geoDataset->GetProjectionRef() << endl;
and it still seems ok....
any ideas??
Thanks,
ml
Michael Logan (650)-604-4494 QSS Group,Inc./NASA Ames Research Center
Task Lead, Visual Cueing & Simulation
Task Lead, Dynamic Aircraft Reconfiguration & Damage Adaptive Control
MS 262-6,Moffett Field, CA, 94035
