[Gdal-dev] Elevation Units in DEM or DTED files
Gerald Brandt gbr at MICROPILOT.com
Fri Jun 4 16:22:08 EDT 2004
Is there a way using GDAL where I can find out the units used for
measurements.  For example, is the elevation in feet or in meters?  I
looked at the projection text and couldn't find anything.
Thanks,
Gerald
