[Gdal-dev] SID to TIF
David W. Lowther DLowther at scigis.com
Wed Jun 9 14:34:43 EDT 2004
Andrey,
So if I get the SDK from Lizardtech and compile GDAL with SID support, I
can convert from SID to anything else GDAL supports, correct? GDAL
itself has no size limitation except that of each individual format?
Dave
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Andrey Kiselev
Sent: Tuesday, June 08, 2004 7:40 AM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] SID to TIF
On Tue, Jun 08, 2004 at 08:14:18AM -0500, David W. Lowther wrote:
> Are there any limitations to the size of TIF that can be created when
> going from SID to TIF using GDAL compiled with the Lizardtech SDK? We
> have been trying to decompress some color county mosaics using
> mrsiddecode from Lizardtech without success and it has been suggested
> that this is because there is a 4GB file size limit for the resultant
> TIF
Exactly. TIFF files are limited in 4GB by design.
BTW, you can find the size limits for GDAL supported formats here:
 http://www.remotesensing.org/gdal/formats_list.html
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
