[Gdal-dev] SID to TIF
Andrey Kiselev dron at ak4719.spb.edu
Wed Jun 9 14:54:49 EDT 2004
David,
On Wed, Jun 09, 2004 at 01:34:43PM -0500, David W. Lowther wrote:
> So if I get the SDK from Lizardtech and compile GDAL with SID support,
> I can convert from SID to anything else GDAL supports, correct? GDAL
> itself has no size limitation except that of each individual format?
Yes. But sometimes such a limitation may exist due to a bug in the code
(which should be reported in that case ;-).
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
