[Gdal-dev] Internal libpng update ?
Eric Dönges Eric.Doenges at nadie.lpr.e-technik.tu-muenchen.de
Tue Jun 15 02:02:04 EDT 2004
Frank,
I've had some problems with the (rather old) version of libpng included
with
GDAL not being able to read PNGs created by newer programs, so I've
updated my
local copy of GDAL with the current release version of libpng (1.2.5).
Could you
update the GDAL CVS version as well ? I've prepared a tar file with the
relevant
sources, tested on MacOS X 10.3.4, but since it is kind of large for a
I thought it would be better to send it to you directly, if you are
interested
in the update.
On a somewhat related note, the internal libgeotiff stopped compiling
on my system
a week or so ago; the following patch corrects the problem.
Regards,
Eric
Index: xtiffio.h
RCS file: /cvsroot/osrs/gdal/frmts/gtiff/libgeotiff/xtiffio.h,v
retrieving revision 1.4
diff -c -r1.4 xtiffio.h
*** xtiffio.h   7 Jun 2004 13:01:11 -0000       1.4
--- xtiffio.h   15 Jun 2004 05:47:12 -0000
*** 7,12 ****
--- 7,13 ----
   #ifndef __xtiffio_h
   #define __xtiffio_h
+ #include "cpl_serv.h"
   #include "tiffio.h"
