[Gdal-dev] hdf4, hdf-eos and gcc 3.4 issues
Vincent Schut schut at sarvision.com
Wed Jun 30 04:08:50 EDT 2004
On Tuesday 29 June 2004 21:35, Andrey Kiselev wrote:
> On Fri, Jun 25, 2004 at 10:16:46AM +0200, Vincent Schut wrote:
> > > I believe the attached HDFEOSVersion.h should work
> > Indeed, builds fine with this HDFEOSVersion.h
> Sorry for delay with fixing that problem, but now it should be solved (I
> have tested with gcc-3.3)
Building of current cvs confirmed with gcc-3.4. Have not done any
functionality tests, though.
 Vincent Schut
 SarVision B.V.
 Wageningen, The Netherlands
 www.sarvision.com
