[Gdal-dev] GDAL 1.2.0 Beta Release - Error
    Lorenzo Moretti
    lorenzo.moretti at bologna.enea.it
    Wed Mar  3 06:42:00 EST 2004
>Lorenzo,
>Sorry about that ... my error.  I have fixed this in CVS, committed
>the fix and replaced the beta tarballs and zip.
Thanx
>>Another problem:
>>I have QUICK BIRD image files:
>>Is it possible to fix this error ??
>If you want to reorder the bands it is possible to do so with some tricky
>steps.
>Basically, build a .vrt file corresponding to the input file:
>gdal_translate -of VRT bgra.tif bgra.vrt
>Then edit the .vrt file with a text editor, and change the <SourceBand>
>values around to the order you want.  For instance, change the
><SourceBand> for the first VRTRasterBand to 3, the 2nd to 2, and the
>3rd to 1.
>Then convert the .vrt file back into a TIFF file and it should be reordered.
>gdal_translate bgra.vrt rgba.tif
>Good luck,
OK for this tip but I use Grass and r.in.gdal and this method is not
applicable for user.  The module r.in.gdal read the band in wrong
mode.
It's difficult for the user to use gdal_translate for creating 4 tiff
files before and after to go to Grass and import these tiff files.
This method must be more simple. Why is it impossible to import bands
in right sequence?
________________________________________________________________________
||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
||/|/|  ENEA prot              Web: http://wwwamb.bologna.enea.it/
||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
