[Gdal-dev] GDAL 1.2.0 Solaris build
Andrey Kiselev dron at ak4719.spb.edu
Mon Mar 8 13:36:35 EST 2004
On Mon, Mar 08, 2004 at 12:35:54PM +0100, Fr?d?ric Trastour wrote:
> if test "PROJ_STATIC" = "no"; then
> It seems that the $ is missing before PROJ_STATIC...and so the test is
> always false and the other directories are never tested...
That's it! Fixed in CVS (finally, I hope). Thank you for finding that
problem.
> What does i need to recreate configure from configure.in ?
You need GNU autoconf tool.
					Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
