[Gdal-dev] A build solution for VC7
Ben Discoe ben at vterrain.org
Tue Mar 9 04:17:35 EST 2004
First, thanks Roger for doing this.  I didn't think it was possible!
It tried out the VC7 project files tonight on a fresh gdal from CVS.  It
works.  Only a few minor issues.
1. The Xerces include path, as you mentioned, will vary from machine to
machine - perhaps better to let the developer put it on their VC7 standard
include path and leave it out of the project completely.
2. The recent 'ogr_srs_dist.cpp' module needed to be added.
3. Project files were missing for ogrinfo and ogr2ogr.
4. The 'Release' builds still had Debug-Info output enabled.
5. The output folders were inconsistent; 'Release' and 'Release_DLL' both
appeared for the Release_DLL configuration.
I've fixed all these issues; result is the attached zip.
-Ben
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org] On Behalf Of Roger James
> Sent: Monday, March 08, 2004 12:17 PM
> To: gdal-dev at remotesensing.org
> Subject: [Gdal-dev] A build solution for VC7
> Frank,
> I have hacked up a build solution for gdal under vc7. Just
> uncompress that attached zip at the top level of the build
> tree. The only thing that may need changing is the location
> of the xerces includes [..]
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040309/601a8b3e/VisualStudio.bin
