[Gdal-dev] A build solution for VC7
Ben Discoe ben at vterrain.org
Wed Mar 10 01:08:15 EST 2004
> -----Original Message-----
> From: Roger James
> My next question is. Is there an easy way to get rid of all
> those size_t warnings!
Easy way?  Well, the right way would be to fix 'em.  I tried swabbing out
bunches of them this evening.  It's a big task.  Worth it, in my opinion.
Code that compiles cleanly w/o hundreds of warnings is code you can feel
good about.  But that's up to the GDAL team to decide.
Sure, we could disable warning C4267, but there's not much point in a
cosmetic solution.
> A few minor tweaks.
> I have removed the xerces directory stuff as per Ben's suggestion,
Hmmm, i though i already took 'em out.  Maybe i missed some.
-Ben
