[Gdal-dev] GDAL 1.2.0 Solaris build
Frédéric Trastour support at geoimage.fr
Wed Mar 10 07:23:43 EST 2004
Hello,
I have always the same problem with proj static linking : the configure script try to locate successively
the proj library in sereval directories : src, lib, .libs, ...
The problem is that when the first test fails, the result is "cached" - in a variable - and the others tests are not
done.
Perhaps there is a simple way to disable the caching mecanism used by AC_CHECK_LIB ?
Best regards,
Frédéric.
----- Original Message -----
To: <gdal-dev at remotesensing.org>
Sent: Monday, March 08, 2004 7:36 PM
Subject: Re: [Gdal-dev] GDAL 1.2.0 Solaris build
> On Mon, Mar 08, 2004 at 12:35:54PM +0100, Fr?d?ric Trastour wrote:
> > if test "PROJ_STATIC" = "no"; then
> > It seems that the $ is missing before PROJ_STATIC...and so the test is
> > always false and the other directories are never tested...
> That's it! Fixed in CVS (finally, I hope). Thank you for finding that
> problem.
> > What does i need to recreate configure from configure.in ?
> You need GNU autoconf tool.
> Andrey
> Andrey V. Kiselev
> Home phone:  +7 812 5274898  ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
