[Gdal-dev] optimum overview settings?
Matt Wilkie matt.wilkie at gov.yk.ca
Fri Mar 12 14:23:45 EST 2004
Hi Listers,
What is the optimum number of overviews versus file size when stored in
geotiffs? And if the end goal is viewing perfomance, as measured by an
application like ArcMap? Mapserver?
The gdal_utilities web page[0] gives "2 4 8 16" as an example, however
significant file size savings can be realized if we use just 4-16. What
is sacrificed by dropping 2?
Are powers of two just convenience? Would 3 9 18 36 work just as well?
And does the size of the image determine how many overview levels are
useful? For example a 100mb image might not benefit much from an upper
overview of 16, while a 3gb image might need to go all the way up 128 or
more.
Are there any guidelines for choosing overview levels?
[0] http://www.remotesensing.org/gdal/gdal_utilities.html
thanks for your time,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
