[Gdal-dev] optimum overview settings?
Chapman, Martin MChapman at sanz.com
Fri Mar 12 16:10:14 EST 2004
Matt,
I don't think so.  I renamed an .rrd file to .ovr and then tried to open
it with gdal and it didn't work.  But, you could always dynamically
create them (.rrd) with ArcMap code.  See the attached files to build
rrd files from c++ in ArcMap 9.  You just need the arcobjects developer
kit to do it.  I think it is easily obtainable though, if you have
ArcMap.
Martin
-----Original Message-----
From: Matt Wilkie [mailto:matt.wilkie at gov.yk.ca]
Sent: Friday, March 12, 2004 1:46 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] optimum overview settings?
Thanks for your insight Martin, it helps. :)
Are ESRI's pyramid files (.rrd) compatible with gdal's (.ovr)? It'd be
cool if I could generate pyramids from the command line for all
our images at once rather than at first load time by ArcMap/Catalog.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
Type: application/x-zip-compressed
Desc: Cpp.zip
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20040312/937c4103/Cpp.bin
