[Gdal-dev] optimum overview settings?
Fri Mar 12 16:19:49 EST 2004
Matt Wilkie wrote:
> Thanks for your insight Martin, it helps. :)
> Are ESRI's pyramid files (.rrd) compatible with gdal's (.ovr)?
> It'd be cool if I could generate pyramids from the command line for all
> our images at once rather than at first load time by ArcMap/Catalog.
Matt,
The .rrd files used by ArcGIS are Erdas Imagine files.  GDAL won't currently
generate the correct variation of these to use as overviews though it could
be implemented without a huge amount of trouble.  However, I don't have any
software now that I could use to test the result  and of course it isn't a
feature of any great importance to me.
Best regards,
