[Gdal-dev] new bug in FAST format
Andrey Kiselev dron at ak4719.spb.edu
Wed Mar 17 02:46:06 EST 2004
On Tue, Mar 16, 2004 at 06:32:46PM +0800, Fu Chen wrote:
> I test one of my old program. But find GDAL120b has some problems in
> parsing the FAST format.
> You can see in central_meridian false_easting are not correctly
> interpreted in 120b. What's change in the new version on the FAST
> format?
Well, there was many changes in the FAST driver to support the wide
range of broken mind data distributors. I have found your problem and it
should be fixed in the CVS now.
					Thank you for report,
					Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
