[Gdal-dev] Strange GeoTIFF error/gdal_merge.py
Manuel Massing
m.massing at warped-space.de
Thu Mar 18 11:23:14 EST 2004
Hello Markus,
I had the same problem when creating a TIFF file and
merging datasets which did not cover the entire domain. The problem
seems to stem from uninitialised sections of the output file,
so a workaround is to first initialise the whole dataset with e.g.
nodata or zero values, and then proceed with merging.
I am not sure if this occurs only with tiled datasets, but it might
be an index initialisation bug of some sort?
regards,
Manuel
