[Gdal-dev] Strange GeoTIFF error/gdal_merge.py
Thu Mar 18 12:39:36 EST 2004
Markus Neteler wrote:
> Hello Manuel,
> On Thu, Mar 18, 2004 at 05:23:14PM +0100, Manuel Massing wrote:
>>Hello Markus,
>>I had the same problem when creating a TIFF file and
>>merging datasets which did not cover the entire domain. The problem
>>seems to stem from uninitialised sections of the output file,
>>so a workaround is to first initialise the whole dataset with e.g.
>>nodata or zero values, and then proceed with merging.
>>I am not sure if this occurs only with tiled datasets, but it might
>>be an index initialisation bug of some sort?
> In fact there are no data areas in the final mosaic as the
> tiles do not cover the entire region. So maybe the problem
> is as you describe (unfortunately I have no idea how to change
> gdal_merge.py to first initialise the whole dataset).
Markus,
It had been my intention that GDAL would gracefully handle strips or
tiles that have an offset and size of zero as "auto-nodata".  Apparently
I did not complete that properly.   I will look into this.  Currently
preinitializing to zero should resolve the problem but I realize that is
not so easy to do.
Best regards,
