[Gdal-dev] Maximum image size with PAux driver
Sébastien Grignard sebastien.grignard at archivideo.com
Tue Mar 23 06:49:41 EST 2004
Hello All,
I am assembling a couple of RGB Tiff images in one big PAux using the
gdal_merge.py utility, but the output image is incorrect. I suspect this
is due to its huge size : 133000x88000. I have already looked a bit in
the paux/raw driver code and changed the offset types to long long
without success...
Do you have any idea of what could cause this ?
Sebastien Grignard
R&D Project Manager
Archivideo
40, rue des Veyettes - 35000 Rennes
Tel: (+033) 2 99 86 30 20 - Fax: +(033) 2 99 86 30 21
