[Gdal-dev] Re: OGR C API question
Etienne Dube etdube at globetrotter.net
Mon Mar 29 16:44:16 EST 2004
Hi Stephan,
You have to make sure the SRID reference from the layer table is present in
the spatial_ref_sys table. Otherwise it seems that OGR is unable to apply the
spatial filter. First, if you haven't actually installed the PostGIS
functions in your database, do it:
createlang -U postgres plpgsql <dbname>
psql postgres -d <dbname> -f postgis.sql
Then, you can use ogr2ogr to fill in the rows from a shapefile:
ogr2ogr -f "PostgreSQL" -s_srs
'GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.0174532925199433]]'
"PG:dbname=<dbname> user=<username>" SHAPEFILE.SHP
(Of course, you have to replace <dbname> and <username> by the correct
values.)
I've found that if you don't specify the -s_srs (source spatial ref. sys.)
when importing an ESRI shapefile with ogr2ogr, the SRID row in
spatial_ref_sys won't be created. Make sure you use the same datum as the
data in your shapefile.
Now, spatial filtering should work with OGR on this dataset. However, (correct
me if I'm wrong) the current implementation seems to be broken, it won't use
spatial queries to fetch the features from the table. Instead, it SELECTs all
the data in the layer, and uses a brute force approach (intersection on all
geometries). See the "OGRFeature *OGRPGLayer::GetNextFeature()" function in
ogrpglayer.cpp. So, if you're working on large datasets, methods like
OGRLayer::GetExtent() or OGRLayer::GetFeatureCount() will take a looooooong
time to execute. Same thing if, say, you want to display all the geometries
in a small rectangle; OGR will have to intersect this rectangle with all the
geometries in the layer, which takes some time to do.
Etienne
On Monday 29 March 2004 10:44, Stephan Holl wrote:
> On Mon, 22 Mar 2004 23:38:46 +0100
> Markus Neteler <neteler at itc.it> wrote:
> > On Mon, Mar 22, 2004 at 09:53:21AM -0500, Frank Warmerdam wrote:
> > > Markus Neteler wrote:
> > > >	poSpatialFilter = OGR_G_CreateGeometry( wkbPolygon );
> > > >	Ogr_oRing = OGR_G_CreateGeometry( wkbLineString );
> > > >        OGR_G_AddPoint(Ogr_oRing, xmin, ymin, 0);
> > > >        OGR_G_AddPoint(Ogr_oRing, xmin, ymax, 0);
> > > >        OGR_G_AddPoint(Ogr_oRing, xmax, ymax, 0);
> > > >        OGR_G_AddPoint(Ogr_oRing, xmax, ymin, 0);
> > > >        OGR_G_AddGeometryDirectly(poSpatialFilter, Ogr_oRing);
> > > >        OGR_L_SetSpatialFilter(Ogr_layer, poSpatialFilter );
> > > >Does anyone see why this doesn't work any longer? The spatial
> > > >filter is simply ignored.
> > > Markus,
> > > The wkbLineString should be wkbLinearRing. It looks like the
> > > AddGeometryDirectly() method returns
> > > OGRERR_UNSUPPORTED_GEOMETRY_TYPE if you pass anything other than a
> > > wkbLinearRing to add to a polygon.   The checking may have been
> > > added after the initial implementation though I see nothing obvious
> > > in the change logs.
> > Great, now it works smoothly (tried with SHAPE, hope it does as well
> > with PostGIS data).
> After some testin it does not work with PostGIS-data. It always pulls
> the whole geometries out of PostGIS.
> Does anybody know a solution?!
> Thanks
