[Gdal-dev] gdal on amd64 needs -fPIC?
Alessandro Amici alexamici at fastwebnet.it
Tue Mar 30 10:27:48 EST 2004
Vincent,
> > I just tried to compile gdal on my new amd64.
luck you ;)
> More info:
> both netcdf/hdf and gdal need -fPIC. I tried compiling gdal with -fPIC
> while having hdf4 compiled without, and that didn't work out.
> Might be that gdal when compiled without hdf4 support doesn't need -fPIC,
> but as I need hdf4 support I didn't try that yet.
do you use the standard (libtool) build or the old style one
(--without-libtool)?
in both cases it would be helpfull to have the configure command line that you
use and a snipped of both compile and link commands.
and the actual error message, obviously ;) !
cheers,
alessandro
