[Gdal-dev] A build solution for VC7, gdal_vc7.zip, URL?
Chapman, Martin MChapman at sanz.com
Mon May 3 22:51:31 EDT 2004
David,
Is there a specific reason you need to compile from a VC7 solution (if I understand correctly)?  You can download the source and make files for windows (gdal119.zip or gdal120.zip) from ftp://ftp.remotesensing.org/gdal/ .  Then you can compile the library from the command line using the VC7 compiler following the easy to use instructions at http://www.remotesensing.org/gdal/gdal_building.html  see - windows.   Once the lib files are built in C:\gdal\bin\lib (or wherever you put gdal) you can link to the C:\gdal\bin\lib\gdal_i.lib file from your VC& solution.  Then just include "gdal_priv.h" and you should be good to go.  Let me know if this doesn't work for you.
Martin
	-----Original Message-----
	From: David Lugan [mailto:davidlugan at hotmail.com]
	Sent: Mon 5/3/2004 4:53 PM
	To: gdal-dev at remotesensing.org
	Cc:
	Subject: [Gdal-dev] A build solution for VC7, gdal_vc7.zip, URL?
	Hello GDAL-Dev,
	Does anyone have a URL to the latest (or any version) of gdal_vc7.zip ?  If
	not, can someone email it to me please.
	This file was sent to the Gdal-dev list on March 8, 2004 by Roger James.
	I have been having some fundamental problems (gdalwarp works randomly during
	development + MrSID causes exception on open()) since I started using MS
	Visual Studio .NET 2003.
	Maybe compiling GDAL as a visual studio project (i.e. gdal_vc7.zip ) would
	help me find out what is going on.
	- David Lugan
	_________________________________________________________________
	Express yourself with the new version of MSN Messenger! Download today -
	it's FREE! http://messenger.msn.com/go/onm00200471ave/direct/01/
	Gdal-dev mailing list
	Gdal-dev at remotesensing.org
	http://remotesensing.org/mailman/listinfo/gdal-dev
