[Gdal-dev] MrSID and GDAL daily build
Chapman, Martin MChapman at sanz.com
Wed May 5 10:52:54 EDT 2004
Andrey,
Thank you very much.
Martin
-----Original Message-----
From: Andrey Kiselev [mailto:dron at ak4719.spb.edu]
Sent: Tuesday, May 04, 2004 11:49 PM
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] MrSID and GDAL daily build
On Tue, May 04, 2004 at 03:18:06PM -0600, Chapman, Martin wrote:
> I downloaded the latest GDAL build from the ftp site (.zip), and when
> I add support for the MrSID driver in nmake.opt (VC++ 7) I get the
> following compiler error:
> C:\gdal\frmts>cd mrsid   && nmake /NOLOGO /f makefile.vc   && cd ..
>         cl /nologo /Ox /MD /EHsc -I..\..\port -I..\..\ogr
> -I..\..\gcore c:\Software\MrSID\include -I..\gtiff\libgeotiff
> -DMRSID_DSDK_VERSION_32 /c mrsiddataset.cpp cl : Command line warning
> D4029 : optimization is not available in the standard edition compiler
> cl : Command line warning D4024 : unrecognized source file type
> 'c:\Software\MrSID\include', object file assumed
> cl : Command line warning D4027 : source file
> 'c:\Software\MrSID\include' ignored
MRSID_INCLUDE should contain -I$(MRSID_DIR)\include, not just the
$(MRSID_DIR)\include. -I switch was lost in the nmake.opt. Now fixed.
						Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
