[Gdal-dev] Another Question about OGRDataSource::ExecuteSQL
jody at ifi.unizh.ch
Wed May 5 12:37:26 EDT 2004
Hi
I assume that the SQL statement passed to ExecuteSQL
refers to the attributes of the features in the Datasource.
If the DataSource contains only one layer,
everything seems to be well-defined, because
all features within a layer must have the same sorts of attributes.
But what happens if the datasource contains more than one layer
(which it can, corresponding to the explanation in ogr_arch.html)
which have different attribute schemas?
Or does an additional restriction apply to features in a
"multilayered" Datasource?
Thanks
Jody
