[Gdal-dev] Problems Linking with Stubs in the precompiled downloadable Win32 Binaries.
Pool marisap at telkomsa.net
Tue May 11 01:56:35 EDT 2004
Thanks, thanks and thanks. I'm overwhelmed by the amount of support I've
received in just a few hours of posting my problems - thanks Frank, Martin
and Ben and thanks some more. I'll keep an eye out for those libraries -
I'm still battling to get GDAL compiled on my machine but I'm learning a lot
in the process too.
Regards,
Louis.
-----Original Message-----
[mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Frank Warmerdam
Sent: 11 May 2004 02:55
To: gdal-dev at remotesensing.org
Subject: Re: [Gdal-dev] Problems Linking with Stubs in the precompiled
Fam. Pool wrote:
> Linking...
>    Creating library Debug/MapViewer.lib and object Debug/MapViewer.exp
> cMapVisual.obj : error LNK2001: unresolved external symbol "struct
> ogr_style_param *  asStylePen" (?asStylePen@@3PAUogr_style_param@@A)
> cVectorLoader.obj : error LNK2001: unresolved external symbol "struct
> MapViewer.obj : error LNK2001: unresolved external symbol "struct
Louis,
I have reorganized the code using the asStyle*[] arrays in GDAL's CVS tree,
and this problem should no longer occur if you work against the latest GDAL
(the source snapshot to made later tonight).
I will try to prepare an OpenEV_FW release with all the latest libraries
in the next few days.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
